Hi, everyone.
There’s one troublesome situation that was tried to be solved by various options. A brief disclaimer: I’m using 2020 version of SOFiSTiK (don’t know whether this piece of info will be helpful or not )
So, the problem is related to variables. As you see (photos are below) the task was to create an “unusual” model of the extradosed bridge. The most problematic stage is creation of kind of “fin” (or “hump”, whatever) where the prestressed tendons are supposed to be implemented.
Watched some videos where the 2016-2017 versions, however, had been used I just repeated the same actions trying to link some points of cross section and specify variable (#ZF) to vertical coordinates. Next the values and rules of alteration for variable were set.
The result was inadequate: the only one value of variable specified in the tab “Cross section properties” had been applied to model of bridge… All the rest rules and values were neglected without any notification of errors or at least warnings during calculation of FE-model!
There were many attempts to fix that: various initial values (0, -0.35, etc.), using complete and incomplete list of placements during specifying the values and rules for variable, changing of rules, even testing the other types of solid CS (nonsense, but it failed too )
Dear colleagues, if you have any thoughts on problem or you’ve encountered with something similar, please share your solutions
Respectfully,
Cyrill
