I want to define my own palette in Wingraf for use with filled areas for required reinforcements. After defining my palette/filling in WinGraf, I want to save this to a user database so that I can use this for several projects. How can I do this? Or is it easier/better to define this in Teddy?
Thanks for your reply!
Could these lines which starts with “FILL” be saved into a wingraf.def file with a title reference? Then I would imagine it would be possible in WinGraf to select this from the properties of the filled area?
-> Prepare a wingraf.def file with your preferred settings.
-> Place it in your project folder (where your cdb is)
-> in the setting for filling there are 2 buttons for default values (original=sofistik; user defined=your def file)
→ Prepare a wingraf.def file with your preferred settings.
What is the syntax for a wingraf.def file? I can’t seem to find an example of such a file anywhere.
How would it look if I e.g. just want all text to be bold?
