Hello, in Teddy 2023 I have a problem with an error:
I suppose that problem is if I have 2 “+apply…” rows consecutively.
Does anyone have a similar issue with this?
Why is this good? v2022 works without problems
Dear Marko,
thank your for your feedback. Indeed in version 2023-0 this is not working. With the upcoming service pack 2023-1 this will work again, as expected.
In the meantime, you may use a simple workaround and add
+prog template
head
between every +APPLY sentence. Just a little work, but you will get your file running again.
Sorry for the inconveniences.
Cheers Martin
