Is it possible to make the software to “look” on the solid section like the T beam? I’m talking about T beams in building. So, if one using T beam from standard section, the software automatically levels the beams (if beams are modeled like centric beam) and ejects the overlapped concrete. My question is - is it possible to make solid section of T and L shape and then to make the software to take into acount overlapped concrete and level the beam corectly - like when it is modeled like T beam?
Hi Nemanja,
the correction in the system visualization (Animator) will not be done for solid sections. But the forces will be the correct ones - the T-beam philosophy in ASE is also used for solid sections and the overlapping part is taken into account.
Nora
