Hello Everyone,
I want to put an eccentric line load to a beam on Sofiplus. However when I insert the offset of the load I don’t get any graphical representation of the offset. Should i get one or this is usual?
The Name/Numb selection must be filled or be left blank?
The eccentricity of a structural line load is not visualised in SOFiLPUS(-X). If you want to check the definition you have to look at the used load within the Graphic (Wingraf).
Graphic > Loads > Used loads > select load case
If the eccentricity refers to a specific geometry point, you must fill in the name field. Otherwise you can leave it empty.
