I am using Sofistik 2020. I am looking for an easy tool to filter beam forces based on the groups . Do i have to filter each time by using range option in filter or is there a tool i can use to select the required groups alone to display the results? I heard that option was there is previous versions.
Hey, Jishnu
Insert a new Teddy text Task
Copy the given text
Change some parameters (Hit F1 on a certain line for help)
+PROG RESULTS urs:14.1
HEAD GET SOME RESULTS
GRP 1 $ *** Here is your line ***
XLSX NAME “C:\Users\Engineer\Desktop\test1.xlsx” WS “XLSX-Export” ROW 1 COL 1 CLNM YES TIME NO CDB NO ELEM NO FILT NO RESU NO
JOIN
DBO$FILT NAME “beam_for.nr” TYPE BT OPTI YES VAL1 10001 VAL2 10005
LC NO 1
TXTP SHOW SIGN OVLP AMAX
BEAM TYPE MY STYP BEAM REPR DLST $ Don’t forget about this one
END -
Run the Task
Look at results in Excel file
