TVAR– Template Variables, has item “SCOP”, it means Scope of variable
But there is no example about how to define the “Scope”
The scope of a TVAR is used to set a variable for a restricted (local) area. This means you can change variables within a defined scope. A common use case is to change the boxed values during a specific program cycle.
For example:
TVAR “ALF-CE” 0.85 SCOP DESI
This command reduces the e-modulus during a specific period for example during an AQB run.
You can check out a few useful commands by opening the Task “Steel Buckling Resistance (Beams)” within the SSD. Just change a few parameters (click “OK”) and open the Text Editor of the Task (Right-click on the Task > Text Editor). Now you can see that the program changes the boxed values for a specific program run (here BDK).
With this method you can locally change most of the boxed values of the project.
open a SSD Project > System Information > Boxed Values
