Hi everyone,
Momentan I’m doing a physically nonlinear analysis with the objective to get the internal work of the structure in each load step. For this I need the curvature of each element in each load step.
Moment is easy to get as a table from Result (postprocessing), but I only find the curvatures in Graphic (WinGraf) as a representation or as a list for all elements but for each load step.
My questions are the following:
Is there a way to extend the results in Result (postprocessing) so that I can also read the non-linear results (like the Beam Element Forces ) and then export them to Excel?
Is there a way to generate a list or test file from WinGraf with the curvatures of all elements and all load steps at the same time?
Thank you for the attention.
Johana
