Im trying to calculate acceleration of the footbridge loaded with walking pedestrian. The bridge model was generated from SOFIPLUS. For the purpose of modeling the walking pedestrian i used the TEDDY EXAMPLE - STEP INTELLIGENT LOAD where load is connected to the moving spring defined with input MOVS in ASE module. In the example, springs are defined with PROG SOFIMSHA. I tried to model springs in SOFIPLUS so i can use them for input MOVS, but those springs are not connected to the model ( it gives me error " the coordinates of the SPT are not lying within the plane of defined system). In the EXAMPLE spring used for MOVS is also not lying in the plane of defined system, it is conneceted with the NODE that is 0.5 m above the plane of system.
Finally, my question is, is it possible to use the MOVS input with the spring defined in SOFIPLUS and if so, how to connect it with the model?
Thank you in advance
