I am moving my loads around, and i have to make cuts manually each time, because the placement of max/min moments is different each time.
Is there a simple line of code that just places a cut over max/min when im pulling my moments plots from the cdb? Below is the code i use to pull moment plots from my cdb file.
#define project=…\Output\pl12_sls_edge
PROG WING urs:1 $ MAX MXX for report
HEAD
UNIT 0 SET IN $ default unit set
CTRL OPT GSTR VAL DEFA
CTRL OPT REPR VAL YES
CTRL OPT AXIS VAL DEFA
PAGE LANO 1
SIZE TYPE URS SC 0 MARG NO
SIZ2
AND POSI 1 POSL 0 POSR 100 POSD 0 POSU 100
SCHH H6 -0.160000 H8 0.6
SCH2 DIRE DEFA
FILL TYPE ISOL NUMB 20 MODE ‘-’ DMOD RDEF
LC NO 90901 DESI 1
GRP NUMB 0 YES GLN
GRP NUMB 1 YES QUAD,GAR
GRP NUMB 2 OFF
GRP NUMB 3 YES SPRI
GRP NUMB ASTR OPTI OFFL
VIEW TYPE DIRE X 0 Y 0 Z -1 AXIS NEGY ROTA 0
DEFO TYPE NO EXPO 0 SMOV NO
SELE NUMB 0
QUAD TYPE MX UNIT DEFA SCHH NO STYP NODE FILL AREA REPR DISO AVER NO
