I have a beam structure modeled with SofimshA and I already have the beam forces, calculated with ASE module.
I would like to know if it is possible to do linear combinations of beam forces to calculate normal stress for each node of the beams that a I have in my structure. However, I would like Sofistik to use different coefficients for each node, which I would give as input data in a list in Teddy.
σ_(i,j) = a_(i,j) N_(i,j) + b_(i,j) M_(i,j)
i = beam number
j = start/end beam node
a = list of coefficients given as a list in Teddy
b = list of coefficients given as a list in Teddy
N, M = beam forces in database
σ = result to be storage in database
Could you inform me if I can do this kind of linear combination on Sofistik?
Carlos
