I am writing a masterthesis about BIM in geotechnic.
I created a subsoil model (Imported in Revit as .dwg) and a model of the shoring of the building pit in Revit (without geotechnical verifications).
Now I want to model the reinforcement and do the geotechnical calculations. I will model the reinforcement with Sofistik in Revit.
So I have one question and I couldn’t find a good answer for that on your website:
Is it possible to directly import the geometries from Revit into Sofistik and make the geotechnical calculations there?
I only found the application WALLS-Verbau, but I didn’t see, that there is a good interface to Revit there.
Thank you very much for your help.
Janosch Sauerbrey
