Is there a way to integrate BEMESS reinforcements, and get a nice view in wingraf as if you were integrating forces?
Thanks and regards
Thanks and regards
What exactly do you want to do? In the Graphic (Wingraf) you can select different types of visulisation.
Graphic > Representation > …
Sorry, I should’ve explained better. The question is whether you can display integrated reinforcements by layer or not, because if you set CTRL LCR
in SIR, you only can display the total quantity of longitudinal reinforcements:
But you can see the results separated in Report:
+PROG AQUA urs:2
head
NORM DC US NDC AASHTO-2014 COUN US UNIT 5 LANG 1 G 10
CONC NO 11 TYPE ACI FCN 49 GAM 25 TITL 'C 49 MPa'
STEE NO 20 TYPE B FY 420 FT 420 TITL 'B420A'
+PROG SOFIMSHC urs:1
head Geometría del modelo
syst 3D gdiv 10000 posz
sto#b 10.0
SPT NO 1 FIX PP
SPT NO 2 X 20.0 FIX PP
SPT NO 3 X 20.0 Y #b FIX PP
SPT NO 4 X 0.0 Y #b FIX PP
SAR NO 1 MNO 11 MRF 20 T 0.50[m] GRP 1
SARB NA NE
1 2
2 3
3 4
4 1
ctrl MESH 2
ctrl HMIN 1.0
+PROG SOFILOAD urs:3
head
LC 1 TITL 'Load'
AREA REF SAR NO 1 P1 10
+PROG ASE urs:4
head
LC ALL
+PROG BEMESS urs:5
head
GEOM - HA 55 DHA 10 HB 55 DHB 10
DIRE 0 0
CTRL LCR 11
CTRL TYPE ULTI
CTRL PFAI 1
lc 1
+PROG SIR urs:6
head
CTRL LCR 11
ECHO REIN YES
DEL#L
STO#L (0 20.0 1.0)
LC 1
GRP 1
LOOP#I L
SECT NO 1 XM #L(#I) YM #b/2 ZM 0.0 $$
NX 1 YMIN -#b/4 YMAX +#b/4 ZMIN -1.0 ZMAX 1.0
ENDLOOP
