When analyzing area members, some of the times some parts of quads are having higher internal angles:
I keep fixing them, however, the problem is that you can only see 5 of these errors at most, whereas the rest are suppressed. Is it possible to see the whole list of errors without suppression?
It is not possible to extend the list of identical warnings.
You can try to search the relevant elements with the programs System Visualization or Graphic.
To avoid this message try to optimise the general settings for the finite elements, such as element size or geometry.
