Hello everybody,
I am modelling a concrete slab using Teddy. Beam elements with T and L sections are utilized to represent the concrete beams. I am defining the cross-sections using AQUA commands SECT, POLY and VERT.
SOFiSTiK automatically positions the beams at the gravity center of the cross-section. For the case of L section, the gravity center is located outside the beam itself. As a result, the beam is not modelled in the correct position (see the attached sketch).
Is it possible to override the position of the gravity center of the L cross-section, so that it coincides with the gravity center of the rectangular part of the section?
