is it possible to define a cyclic loading protocol that is displacement-based?
I want to calibrate a FEM model to the results of experiments on timber walls. The loading protocol was calculated according to the standard ISO21581.
Petya Gruewa
JFH
November 3, 2022, 11:02am
2
Hello Ms Gruewa
Have you tried the ASE command PUSH
The general procedure is described in the following TEDDY example.
TEDDY > File > Examples > ase > english > nonlinear_quad > push_over_quad_deformation_controlled.dat
Detailed explanations can be found in the ASE manual.
SSD / TEDDY > Help > User Manuals > All Manuals… > ase > chapter 3.8 PUSH - Push over analysis
ptaleva
November 12, 2022, 1:10pm
3
Dear Mr. Höller,
I tried the procedure in the aforementioned example, but the program does not increase the displacement in the ASE task with ULTI. The displacement is added in SofiPLUS as a WXX displacement.
Petya Gruewa
