is there a TYPE statment in the sofistik_daten.bas file (VBA) that allows you to get the axial strain and stresses results in the cross section of beam elements (AQB)?
I was able to access my CDB and get basic information, such as node numbers, using the example files. However, I would like to go further and enable the extraction of results using the VBA codes.
Thanks
