This is a simple question for a new Sofistik user, but I am wondering if there is a way to do surface to surface contact interaction in Sofistik.
I am specifically trying to couple a rigid body to a pretensioned membrane structure so the tension of the membrane applies a force to the rigid body.
Let me know if anyone can help with this coupling problem.
-H
sfr
May 12, 2021, 1:20pm
2
Sofimshc -> SARS
Either a fixed or a spring connection are possible.
thanks for the help,
Is it possible to do these fixed and spring connections between geometries when designing in Rhino/Grasshopper?
-H
JFH
May 17, 2021, 7:58am
4
The coupling of two structural areas is not directly implemented within Grasshopper. But you can try to add a custom CADINP Code that includes the SARS command.
https://www.sofistik.de/documentation/2020/en/rhino_interface/grasshopper/command_reference.html#structure
