Hi
I’m trying to change some parameters for areas by groups but I can’t seem to get it to work. Please see my example code below:
+prog aqua urs:58.2
head materials
MAT 1 E 35000
MAT 2 E 20000
+prog Sofimshc urs:21.1
SYST 3D GDIV 100000 GDIR NEGZ
CTRL MESH 1
loop#i 5
loop#j 2
let#ii 11+#j*10+#i
prt#ii
SPT #ii X 500*#i Y 1000*#j Z 0
endloop
endloop
SLN 1 NPA 11 NPE 21 GRP 1 FIX F
loop#i 2
loop#j 2
let#ii #i*2+#j
SAR 1+#ii MNO 1 GRP 1+#i T 100
SARB TYPE OUT NA 11+#ii NE 21+#ii
SARB TYPE OUT NA 21+#ii NE 22+#ii
SARB TYPE OUT NA 22+#ii NE 12+#ii
SARB TYPE OUT NA 12+#ii NE 11+#ii
endloop
endloop
I would like to change the material of group 2, which I would believe should be done like this:
SAR GRP -2 MNO 2
It is possible to change the parameters using this syntax, but only by element number and not by group apparently?
How would I go about changing parameters for an entire group?
Thanks
