In the verification file beam_elem.dat, on lines 59-62 there are records without specified mandatory items, see the screenshot. How does it work? Are these lines ignored during the file processing?
Well GRP
has a default of “all loadcases”.
The remaining three commands don’t really make sense w/o any input.
In this case they are definitely ignored and you might as well skip them.
If you use the interactive version of the resultviewer or wingraf and save the file, this is what the generated text often looks like.
However I’m not sure if this is always the case.
E.g. ASE → Command LC has a mandatory LC Nr, but seems to default to ALL if you skip the specification.
So I wouldn’t trust it.
