Hello everybody,
Is it possible to activate particular modules/programs INSIDE an if statement in Teddy?
I mean something similar to the following code:
if (condition)
+prog …
head
else
+prog …
head
endif
Hello everybody,
if (condition)
+prog …
head
else
+prog …
head
endif
As far as I know this is not possible.
If you require this program behavior, you have to work with grasshopper or another supported programming language.
In Sofistik-manual is written (i don’t no if it works):
2.9.4 #IF - Conditional Input
IF THEN ELSE constructions can be defined. This means that larger input blocks can be inserted and removed, which is more difficult using the IF constructions in CADINP, and that several program calls can be grouped in one block.
The relevant control lines are familiar to all C-Programmers. In the first column the following possibilities can be used:
#if expression
any line, also PROG and SYS
#else
#endif
”expression” may be just the name of a block or a variable which is evaluated to be true if it is defined and not empty and not equal to zero. But it might be also a comparison $(MODE)==EC or $(MODE) < >EC or $(MEMBERS)>3. Be aware however that the comparisons are purely lexically based on strings, adjusted to the right for numbers, and to the left for all other cases. Therefore we have A < B, AA < BA, 10 < 18 but unfortunately also 10.0 > 12.
If ”expression” is not true, the first block will be skipped and the block after #else will be used. Naturally the second block can be omitted if not needed.
These constructions can be nested in up to 32 levels. An unmotivated #else or #endif will lead to errors, as well as an unfinished construction.
Example:
#define DOAQB=0
#if DOAQB
PROG AQB
HEAD …
LC …
DESI …
#endif
Ah yes you are right.
#if works as described.
Thanks for the input
It works. Thank you very much!
