Hallo I have been modelling my bridge and at the construction stage i keep getting an error
Hi Brian,
did you follow the recommendation from the error message? You will find this example file, when you start TEDDY and goto the “Examples” button from the start page. There you navigate to CSM>english>csm13_quad_weight_lar_activation.dat
Check the input from this example and use it accordingly in your project file.
Hope that helps
